Network/TCI-based CAT Control
Ok i understand the this is a bit of an odd duck request, but that’s why we are Hams.
Hoping the API might help with this. Starting with adding Multi radio CAT switch so SO2R can change what radio is being operated. Also see last paragraph for IP.
Now the more might be just me operation I have a PI connecting my 2 radios, 2 Ant switch and rotor, and cross over switch. I do this through a custom program to share freq, and control devices on web interface. Can it be looked at to get the CAT information from HAMLIB via IP/Port not serial connection?
Or at least radio CAT from IP?
I also know i can explain better in person. So open to email more indepth.
@AC8HZ Hey John,
Adding ip/port vs serial connections are coming, its on our list.
Thanks, look forward to that, also being able to change between multi radios as well. Hope to see it.
John
