I am trying to use WRL to log a POTA outing for the first time (and offline after the fact) and am not sure EXACTLY how the logging process works. In the “create a new logbook” section, do I create a new POTA “logbook” for each outing or do I create a new Logbook for POTA and continually add to that logbook with each additional outing?
I find it to be easiest to create a separate log for each POTA activation.
You can label it however it makes the most sense to you:
US-0911 March 8 2026 works for me, but you can certainly use a different process if you like.
If you were to use just ONE log then it will get unwieldy after a time and although POTA will probably reject any duplicates it will be harder for you to keep track of the different parks.
Thanks. I appreciate your help and will probably take your advice on the Label procedure. It sounds simple and efficient. 73
