@W7AAF If you are not using gridtracker you can follow the instructions here: Wsjtx -> gridtracker -> wrl log - #2 by K4AZE
If you are using gridtracker then you can follow the instructions here (just ignore the parts about n3fjp, the setup is the same though): Gridtracker, WSJT-X, and N3FJP Integration Guide - World Radio League
Its just all about setting the UDP ports correctly and selecting the correct logbook you want the QSO’s to go into in your WRL account
