Hello, can anyone help me solve the CAT problem with my FT-897D and FT-857D radios? When I connect both radios to the CAT, they start switching between VFOs continuously. Has anyone else experienced this? Any help would be greatly appreciated. Thank you.
Just here to confirm I am having the same problem. Did you find a solutions?
Buen dia mi radio en el yaeso ft897d y el la configuracion de programa de cat lo puse en el ft897 y se conecto y dejo el problema solo sigo con problemas con el hermano el ft857 ese si no lo he soluciona ,pero lo uso me toca solo con el primero
@YV1GIY What was the correct settings for your FT-897D that you got to work with the cat control app? @NA5T is having some trouble.
To be clear, I have an FT-857D which switches between 2 frequencies, both of which I had just used, so they are not random. CAT Control is setting the radio alternately between the 2 frequencies so the baud rate and comport setting are correct. I hope to get this working.
@NA5T see above
I use that setup, corrected for FT857 and comport. CAT works. WRL changes the frequency once per second, and the frequencies in the WRL display match the radio frequency. I suspect WRL does what many programs do, reading the radio. In case someone manually changes the radio, WRL catches it. And something goes wrong.
Thanks for replying.
