QTH not reporting correctly after ADIF import
My QTH (EL88pc) is not being reported correctly after importing an ADIF file. When i import the same ADIF file into other apps or websites, it does log my QTH as EL88pc. Is there a bulk edit function to change all my QSOs?
@W1MPC You can use the QSO manager to update your location by following the steps in this screen recording:
Let me know if you have any trouble.
Also after you’ve updated your existing QSO’s if you’ll goto your profile then click on ‘my operating locations’ and set a saved location and then go into your logbook and then click the gear icon in the top right to go into the logbook settings you can select that saved location and set it in your logbook. That way any new QSO’s you make will be logged and mapped correctly.
