Request Confirmation and Filters
I just did my 1st Request Confirmations and noticed there is no filter option for Unconfirmed. That is exactly what you need with Request Confirmations.
The Bulk Request Confirmation Details came back noting 26 with no emails. You can’t click on the 26 to see/select which ones. Seem difficult to figure out who I need to look for. I tried several in qrz lookup and found emails.
Is part of the problem that you have to be connected to all loggers to see where someone uploaded? Mine are all digital via WSJT-X why isn’t there a way to embed a code like 2FA code in the record to verify it authenticity without all this chasing down logs.
@KZ4MW Hey Wallace,
It will only send confirmation emails to unconfirmed contacts and not contacts that are already confirmed in WRL. When using the QSO manager there is a ‘Conf’ column added by default (however you can add/remove various columns that are listed), so at a glance you can look and see which contacts are confirmed and not confirmed, be able to select those QSO’s and then click the ‘Request Confirmation’ button.
