spotting board does not work well with changes old board worked better
What is wrong with the new one??
@WC5T Hey Jeremy,
I’ve reached out to the team for them to take a look at this. I’ll reach back out after they’ve had a min to dig into what might be happening here.
thank you
@WC5T try logging out and logging back in.
so working a bit better today reset filters a few times however just logged a contact and went back to spotting no highted contact which was widely used on old spotting then 4 minutes later appeared bu t not pronounced enough
@KO6INC Charles, when you log a contact the spot is highlighted just like before, everything works exactly the same functionality wise. its just the UI that is different now, with many more options. There are multiple views in the spotting tab now, one of which is almost identical to the previous spotting tab (see below).
The spotting updates were tested very thoroughly for a couple of weeks prior to being released. The one thing that we have taken note of is that the dupe flag is not showing on the logged contact inside the logbook but it is showing in the logging fields. We will be pushing a fix for this soon.
