@KE8RRG This is how the logic currently set. The distance and mapping is based off of if the other user is at a park or not which is determined by the āTheir Parkā field. Additionally if you are doing a pota activation (or sota, iota, etc) and have that activity set and your activity reference added (ie pota park) to your logbook it will use that location instead of your āsaved locationā or qth location.
Thatās fantastic. Just one more question: does that apply for Hunters? Not just activators. It would be great if it is the same for a Hunter. I contacted W1IP who was in FL in a park and the log logged him in CT. I see in my log now that he didnāt have a park registered. Just would like to confirm the same logic applys for Hunters.
@KE8RRG Yes the same logic applies for hunter. As long as you add in the park the other person is at in the āTheir Parkā field it will map it and log it correctly.
