this park spans across country. I am in ontario, it passes right through local park here. But when i logg this park it shows me in alberta. This Trail system spans 28000 km coast to coast.,
this is messing with the data on the leader boards showing a location I am not and confusing others. When i change locaiton details in the log itself, the pota park overrides that.
@VE3YHW We pull the park data directly from POTA instead of using our own data or populating it ourselves. You can update your location in your logbook settings either by lat/lon, gridsquare, and/or state via the ‘custom location’ option or you can create a saved location and assign that saved location to your logbook the same way you would setting a ‘custom location’. I hope this helps.
@VE3YHW Interesting. ok I’ll reach out to the team and have them take a look as it should be updating once you update your location info. First i’ve heard of this one.
I went to check out your account to see what was going on. I’m assuming your referring to the logbook ‘TRNS CAN TRL @ CA-5082’ correct? And the correct gridsquare is GN36mu ?
I’m not seeing any QSO’s in that log so its not going to show anything on the map or leaderboard. I did add a test qso with myself and it maps correctly according to the gridsquare.
