I’m having trouble logging contacts. Pressing Log Contact does nothing. Simmilarly, I get the same result when using the Android app. I’ve cleared the local browser cache etc. Anything else I can try or should I send in a bug report?
@KE4DRJ You can submit a bug report. Are you adding one decimal when adding the frequency? ie 14.22250 instead of 14.222.50. It should be logged with only one decimal, however I though we pushed a fix for this already, not sure what else it could be.
I checked that, I enterd the freq. as 10.119 Mhz. I logged from the spotter page, so everything was auto pasted into the fields. I’ll fill out a bug report, Thanks for the help.
I just had the issue happen again, It seems to be related to the auto import of the freq, when copying from the spotter page. freq. was imported as 14.062, But I had to type it in again as 14.062, then the contact would save.
@KE4DRJ This should be resolved now. We’ve pushed a fix and in your bug report ticket you confirmed its working as expected now. Let us know if you run into anything else.
