Is there a way for the map software to “sense” where your contacts are and not put the WRL web address across that part of the map?
@W7YBY Its trying to fit all the contacts (or as many as possible) into the view at once.
Yep, I get that. But if I had numerous contacts in the MT ND WI, Canadian border area the web address would be blocking them. I was just asking if the web address could be set up to know that it would be blocking contacts and relocate itself elsewhere? If the answer is no it can’t, then it is what it is.
