The globe image showing contacts is pretty slick. When I click on a contact route using my phone it shows the to/from callsigns; however, doing the same on my iPad while in portrait mode results in the pop up showing below the display field so it isn’t visible. If I rotate to horizontal display then only the top portion of the popup is visible. Scrolling down to see the popup deselects it so the popup disappears. Maybe that popup could be moved to above the globe image?
Thanks Steve!! Glad you like that visualization, it was really tricky to build lol!
Thanks for calling that out - we will work this into our UI enhancements. We have some pretty cool updates coming for the globe view too and I’ll keep you posted!
Not sure if it’s possible but what about also displaying some additional details to that popup such as frequency and mode? It’s cool to visualize that Fred and Ginger made a contact but knowing what band and mode would be useful if I was looking for either of them on the air.
Hi James
Thanks for the nice looking log book, I do like the QSO Map feature, just can’t figure out how its supposed to work though?
So I manually added 10 QSO contacts tonight, am I not supposed to see these on the map?
You’ve seen Grid Tracker? I no longer use it, but that had a nice looking map, that showed where you being copied, maybe look at something simular, is it in the pipeline?
Looking forward to feedback from the WRL staff ![]()
Hey Stephen!! Thanks so much for joining!
Looks like there could be a bug on the map, you should be seeing contacts. We’re going to look into this for you right away.
We’ll also be allowing you to get your own personal globe view too
I haven’t used Grid Tracker before, but that’s a great suggestion!! We’re going to be rolling out all kinds of new analytics and trackers so thanks for the input there.
73 and WELCOME!!
Welcome KD4, to tje WR League
