I carry my iPad and use it for logging so one day it connected to my works WiFi and I came home and set up my gear and started working ft8 and my location did not change or should I say my grid so know I have 2 spots sending outbound is there a way to combine them to my main grid?
@W4DLG Hey Daniel,
Yes, using the web app you can go into the QSO manager and select the contacts you need to change your grid square for and then click the ‘bulk edit details’ button. Then click the ‘Location’ button at the top and either enter the grid square under ‘Custom Location’ or selecting a ‘saved location’ you already have saved. That will update your QSO’s with the correct grid square. Let me know if you have any questions or need a hand with anything. Happy to help.
Is there a way to select the grid and then bulk select?
Nevermind I figured it out. Instead of searching for the wrong ones I just selected all and made the change thanks so much for replying have a great day 73
@W4DLG Awesome! Glad you got it sorted! Let us know if you need anything else!
