CQWW - Entry Category Options
Hi there, I can’t seem to find on the CQWW template the Entry Category options (Single Operator / Overlays - soapbox). It would be sweet if they could be added on the template, so that we don’t have to manually enter them later at the Cabrillo. Many thanks for your fantastic work in WRL!!
@SV1TRU Are you meaning in the Cabrillo header options when you go to export the Cabrillo?
Hi Brad, thank you for your swift reply! I am refering to inputing the Class (for example in my case: Single Op - Single Band - QRP - Rookie) I can’t seem to find the relevent fields in the “CQ World Wide DX, SSB” logbook that is created - maybe they are to be inputed at a later stage when exported to Cabrillo?
@SV1TRU Yes when you go to “Export Cabrillo’“ for your logbook it will give you a place to enter all of that.
Got it, had not reached that point. Thank you very much for your immediate support!! Kudos
