Documenting P2P
I am fairly new at POTA and am now learning I should be documenting park to park. What is the chronological process of doing this when logging contacts?
@KD9ZAB Park 2 Parks (p2p) is when you are doing a pota activation at a park and you make a contact with another callsign that is doing a pota activation at another park (or even in the same park as you). In this case you would just enter their callsign and then in the ‘TheirPark’ field enter the park number they provide you & then log the contact. Thats all there is to it :wink:
Let me know if you have any other questions.
I appreciate it. I have only activated only 6-8 parks to date and have been failing to log these. I will going forward. There is so much going on, I get in a hurry and have failed to do so. I am in such a hurry to log the call, I have not been doing the park numbers. To the activators out there, I will do better and I apologize. KD9ZAB
@KD9ZAB no reason to apologize!! Here is where you’ll enter it either on the web app or the mobile app :wink:
