Especially in a contest situation, it can happen that after filling in all the required logging fields, you realize that the callsign is incorrect. The quickest way is then to delete the callsign field and completely rewrite the callsign. And the quickest way is the way you do it in a contest.
But now I have read the following (and have also tested it in the meantime):
If cleaning up the callsign means that all the information already entered is lost, that would be a disaster.
So my feature request is:
The functionality whereby deleting the callsign field deletes all logbook fields can be enabled/disabled in the personal settings.
Otherwise, WRL cannot be used seriously for contests.
73 Pepe
@HB9EVT It just removes the call sign data (ie name, country, city, grid and notes) it doesn’t remove the freq, band, mode, rst sent/rcvd, power or time.
