Generate cabrillo file [IN PROGRESS]
First time user for winter field day. There are a few improvements I would like to see to continue future use but first I would like to know if there is a way to create a cabrillo file ?
This is in progress, we don’t have it yet!
For Winter Field Day though, you just need to export the ADIF to upload to the Winter Field Day website.
You can do this on the logbooks page
In regards to the Cabrillo File. I took a small part in the ARRL DX this past weekend. Since this is not supported, I had to ADIF to CABRILLO conversion, edit in a text box, then add it as if it were a manual submission to ARRL. This is the first time I ever needed this format. It wasn’t horrific, but it would have been easier.
This should be a pretty easy fix. Adding an “Export Cabrillo” button alongside the “Export ADIF” that just pulls the data from the database and formats it in Cabrillo vs the ADIF standard. I think this is something that will standard as the contesting functionality evolves.
@N0WRL Thoughts?
Agreed with this @K4AZE. We just have to add a screen that lets you edit the header of the file before final export to make sure all the fields are correct! We’ve got this designed, just pending development now.
Perfect! Thanks for the quick response!
