CAT connection follows VFO etc. when manually switching bands/modes. When I double click on a “spot” issues start. The radio switches eg 20m usb to 40m lsb - good - but when I double click back to a 20m “spot” the radio changes frequency but stays in lsb. Also, when double clicking a CW “spot”, the radio goes to the frequency but mode is reverse cw - (CW-R) I wonder if there is a menu item or two that need to be set for normal CAT control. Baud rate is fine. Windoze 11.
@M5GVY Sorry you’re having some trouble. What radio are you running?
Hi Brad. I sent this in recently as a possible bug report and you suggested trying on this forum. So here I am.
Radio is an Icom IC 9100
@M5GVY
well that, and you actually put it in the title lol I need to go back to bed i guess hahahaha. Sorry about that! One thing I thought of after the fact was, and this is going to sound odd, maybe try using the 7300 radio configuration file (from the radio drop down) and see if that makes any difference.
@K4AZE thanks Brad. I’ll try and give it a go later on today.
