Hello wrl a little feedback
hello wrl,
i did my first pota activation today with just use wrl.
every thing works perfect, thank you for the great system.
the only thing i miss, is the confirmations from QRZ and LOTW.
please add this feature, than wrl is the perfect solution for me.
greetings from germany.
73 de DA6XJ kai
@DA6XJ Congratulations and thank you for the support!!!
Since you are a QRZ subscriber you can use the QRZ integration to pull in your logbook/QSO’s from QRZ into a WRL logbook and it will pull in your current confirmations from QRZ. We are finalizing some functionality that will check for new confirmations on QRZ and pull in just the confirmations.
One thing to note is that if you already have the same QSO’s in your WRL account as your QRZ we will not import those QSO’s again as we dont import duplicates, so it wont import the confirmations either, currently.
I hope this helps!!!
