How to confirm a qsl contack in wrl
@C6AJA Hey James,
There are three ways, One a WRL confirmed contact (green check) those are contacts made between two WRL users. Another is a QRZ confirmed contact, you need to enable the QRZ import/export integration (you’ll need a QRZ subscription per the QRZ requirements to use their API). Once you have that enabled you can import contacts from your QRZ logbook and then the confirmations will come in with the QSO’s, also you can use the ‘re-check confirmations’ button in the QSO manager after selecting all QSO’s to re-check QRZ for confirmations. Additionally use can enable the LOTW import/export integration and use the ‘re-check confirmations’ button to pull in confirmed contacts from LOTW.
I hope this helps.
