As a hunter, I just made contact with an activator at the park. He stated he had two other ops there. I have logged one operator, and can add a specific log entry for each of the other two operators.
My question is: Is there a way in my hunter logbook to add multiple operators separated by commas in a single log contact? I tried, and the software “reset” the other autofill fields, like locations.
Yes you can simply just double click one of the spots from the spotting tab (which will load the data from the spotting network - ie freq, band, mode, park reference, etc) then you can enter a comma and the next callsign after the first (example: double click a spot for K4AZE all the data loads in the logging fields and then you can type a comma after K4AZE and then the next callsign (ie K4AZE, N0WRL) and then log the contact and it will log them both as sperate qso records.
You can also do this without double clicking a spot and just entering the callsign separated by a comma
