Need to add additional park in activator log
I activated a 2fer park and thought I entered both parks and then found out I only entered one. Only one shows at top of screen. I don’t see a way to fix in QSO manager and now it seems I have to go back and add to every QSO.
In addition, I activated a WMA and then found out later it was also in a national forest (newbee). Same issue.
@WW5R Hey Jack,
Ok so what you can do is go into the QSO Manager and then use the filter button to filter by logbook, then select the QSO’s you want to update. Then click the ‘Bulk Edit Details’ button then click the ‘My Activities"‘ button in the quick settings bar above the logging fields and add both parks (the first you initially setup the logbook with AND the second park). Then click the preview your changes button and proceed to update the contacts. THEN you’ll go into your logbook and click the park number in the quick settings bar above the logging fields and add the second park number and save it.
This will get it all straightened out and you’ll be able to go to the main logbooks page (with all your logbooks listed) and be able to hover over the action column and have the ability to export your pota logs for both parks.
I hope this help! Let me know if you have any trouble.
DUH! Thanks. Worked great. - Jack/WW5R
@WW5R Don’t beat yourself up! Its not super intuitive
