Today, I had two 2fers in the log. Each time I went in and added the second park manually. Hit save. As I’m looking through the logbook prior to exporting the file for submission, the second park in the 2fer is not visible. Without it, I cannot qualify to activate the park. Where did it go?
We need a way to see the list of logged parks without having to open up each app. It should also be a stat on the stat page for a log, who many parks hunted or p2p. Take forever to verify and I still can’t tell.
Also, when you were adding the second park were you adding the parks comma separated (ie US-1234, US-4321) or were you adding the first park and then clicking it from the drop down and then adding the second park and then clicking it from the drop down?
It would be really nice if you didn’t have to open the edit or view function to see it. Park numbers are so central to what is being done that they should be on the stats page as a list.
Also, I’m doing a 2fer in June. How do I export one file for each park?
When you create your logbook and add both parks to the logbook, when you go to export your logbook it will say ‘Export US-1234 ADIF’ and there will be another one for the other park ie ‘Export US-4321 ADIF’. This is the same process for a 3fer, 4fer, etc
