Is there any way to mark stations which have been worked before? Maybe with a special color? For sure I can found the info when I add the new QSO… but later on I can’t see these stations anymore.
Would be a nice option…
Thanks,
Chris
Thanks,
Chris
@DL8CL Currently when you enter a callsign in ‘Their Callsign’ or you’ve double clicked a spot from the spotting tab, if you’ve made a contact previously with this callsign it will show the number of times you’ve made contact with that user. However it will not be tied to the logbook you are in but across any logbook in your WRL account.
If I’m understanding you correctly your asking to have the callsign or log row highlighted in some way for logged QSO’s that are the same callsign? Because the only other way to do it would be when you do the call sign lookup (ie Enter their callsign in the ‘Their Callsign’ field).
For example If you have logged a contact with me more than once in one or more of your logbooks then my record in your log would be highlighted?
Hi Brad,
Indeed, that would be my proposal. If I could see in the list in my logbook marked either a different Color it would be easier to identify multiple qso…
I was just preparing paper qsl cards and want to avoid multiple mailings.. I had to enter always the Callsign to check..
Best regards
Chris
@DL8CL Definitely an interesting idea! I’ll add it to our list of mini features for discussion.
