New member here..I just started using Logbook…when I first started using I was just using integrate button at end of session and all my contacts from QRZ that I worked for night came into my logbook with no issues (most were confirmed). Now I configured things so my contacts are logged into WRL automatically from wsjtx and gridtracker..(nice they get logged automatically) Issue Im having is all the contacts I made today and yesterday that were auto logged have no confirmation even though most have been confirmed in QRZ.com..How to get my new logged contacts confirmed?…Or do they even have to be confirmed for contests and leader board stuff?
@KJ7LEX No they dont have to be confirmed to show on the leaderboards as long as the contacts were logged in WRL. However we are adding functionality to check QRZ for confirmations only and pull those in. The issue is currently when you log a contact in WRL and you upload your logs to QRZ, we have no idea when the other callsign will upload their logs to QRZ; it could be a day, week, month etc, THEN QRZ will confirm the contact. This is in the works though and coming soon.
@K4AZE Brad, refresh my memory, when you import from QRZ do those imported contacts count toward daily streak? Wifey had a couple FT8 yesterday and we entered one contact direct into WRL but imported others as I wanted to make sure she kept her streak. Thanks! & 73 Jeff WV1DAD
@WV1DAD Unfortunately no, only streamed contacts from WSJTX (or the other UDP streaming options) via the cat control app or contacts actually logged in WRL count towards the daily streaks.
Gotcha @K4AZE Thanks again for everything!
@K4AZE Also noticed streak board is not updating correct numbers. Everyone is one off, streak is 211 for all three top but shows 210 and you should be at 209 not 208. Just FYI if you didn’t see it yet
yeah i think it just hasn’t updated yet. I’ll double check though and make sure nothing is wrong.
