My original QSO’s from QRZ show confirmations but my new QSO’s don’t show as confirmed. They show as confirmed on QRZ though. What am I doing wrong? I do all of my logging on WRL
@K6CDA Hey Chris,
This is the current expected behavior. We are working on some new functionality that will just pull new confirmations from QRZ. The issue is when you make a contact in WRL and the QSO exports to QRZ we dont know when the other callsign will upload their logs to QRZ, it could be a day, a week, a month, etc. Then when the other party uploads their logs to QRZ, QRZ confirms the contact.
Again, we are working on functionality that will check QRZ for new confirmations and just pull the confirmation and update your log in WRL. This is coming soon.
@K4AZE When you fix this, will this make more confirmations work from LOTW as well?
@KJ7ZTH Honestly not sure, we are looking into a way to do the same thing for LOTW but with its OLD OLD API i’m not sure if we’re able to. I’ll talk to the team
@K4AZE Thank you. For now, I am reimporting all of my contacts, first from LOTW, then from QRZ, then from my PC backup ADI file. This way, WRL should acknowledge my confirmations for confirmed QSOs, correct?
@KJ7ZTH If you are using the integrations for QRZ and LTOW then yes it will pull in the confirmations as long as the QSO’s are already not in one of your logbooks in WRL. However it will not pull in confirmations from imported ADIF’s currently.
Thank you. I am thought I was doing something wrong.
