@AC3DS One sec
@AC3DS Hey Drew,
All is well now, sorry about the trouble here. You can export your cabrillo now.
@K4AZE You fixed it, thank you! Your efforts with this are much appreciated.
One other thing that could be helpful. The way I did this was to setup gridracker to send to wrl cat control with only “listen to wsjtx” active. I set the port to 2238 and selected my arrl digi log in the wrl cat control. Then in the general settings tab on gridtracker, I set a udp broadcast to 2238. Now when I log a contact on wsjtx, gridtracker gets it and simultaneously logs to qrz and whatever wrl log I have selected. My wrl cabrillo accepted without issue.
