Re-check name and location for logged QSOs?
Hi! I often use iFTX during POTA, and import the logbook later. Because this is an ultra lightweight app, it doesn’t do any lookup on contacts that go into the ADIF.
When I import the ADI file into WRL, it comes in without the grid and name info. However, when I export those contacts to QRZ, it automatically checks them and enters the missing info in that logbook.
I tried doing a “recheck confirmation” in WRL to see if that populated the data, then tried waiting overnight to see if it happened by magic but it didn’t. Is there a way to get WRL to recheck logged contacts for missing data against the various configured contact lookup resources and fill that missing info in? If not, can that be a feature request?
I attached a screenshot showing the imported contacts in WRL and another in QRZ
If you have a paid QRZ subscription WRL integrates with and pulls missing data.
Using the WRL + QRZ Integration
The other part of the integration allows import/export of the log
Hope this helps
Stay Safe, 73
The problem is that it doesn’t seem to work. At least not in the specific sequence of events I use, which is to import my ADIF into WRL and allow it to push records to QRZ. QRZ takes the incomplete data and completes it on their side. But WRL doesn’t, which results in the screenshots above.
What I’m looking for is WRL to do this checking on file import, the way QRZ does
@KB0RB Hey Jon
For an adif import we dont do this, we just take the data that is in the adif. If you import your contacts via the QRZ import integration (which uses the QRZ API to pull the QSOs - and data) into your WRL logbook then it will have all the data you are referring to.
Yeah, copy that. I’m looking for a way to accomplish that though! WRL is my primary logbook these days and I export to QRZ for the higher volume of/additional confirmations that come with their many years of momentum. I’d love to see WRL start doing that checking on import, so I don’t have to upload to QRZ and import from there rather than uploading to WRL and exporting to QRZ
