What circumstances cause the message “re-directing to CAT Control” and then endless spinning without any success . Most of the time I do not get this but today no matter what sequence I use of getting CAT running and then signing in, I get this message. This morning the best I can do is to get WRL to read info from my FT-710 but 710 again is not getting spot commands to QSY
I am not completely convinced that my difficulties in having a 2-way connection between WRL CAT control and FT-710 are caused by WRL, it may be a Hamlib issue with the FT-710 (assuming WRL uses hamlib) . Today, and few other times in past week , I had difficulty to 2-way connection and tried different attempts to start WRL CAT Control and then sign in , without success . Then, I eventually try again and get a loud “click” from my rig as a real 2-way connection is established. My one-way connections don’t seem to cause this loud click even though WRL says I successfully connected . Today , when I successfully connected I noticed that my rig immediately switch to a frequency that was spot I clicked on 10 minutes earlier when on a previous connection. It is like a spot command to QSY gets “stuck” and magically gets executed on my next successful connect . Polling issue ?
