Hello WRL team! I was looking under upcoming contests and did not see the ARRL Rookie Roundup SSB contest this coming Sunday. Can you add that to the list? Also, is there a contest logbook that you recommend using? Thank you!
@KD9ZAB Hey Adam,
Yes this has been added. To participate in contests on WRL you’ll need to goto the contest page and enroll in the contest which will automatically create the contest logbook for you with the correct contest exchange fields.
Once you open the contest logbook make sure you add your exchange to the ‘My Exchange’ fields below the log contact button
I hope this helps.
