Still kinda new around here and learning…I have states that I have made contacts with but they still show I have not. These are not confirmed contacts, but I have other non-confirmed states that show I have worked them. Any suggestions?
Thanks!
Thanks!
@K9DUD Hey Doug,
The analytics are pulling the data straight from your QSO data within all the QSO’s in your logbooks and confirmations are based on confirmed contacts within WRL (since you dont have the QRZ or LOTW integration enabled).
Here is a screen recording breaking this down:
I hope this helps
I do have QRZ enabled. I have QSO’s logged from several states that the map still shows as states I have not worked. Is there anything else I should do? Thanks
Colorado for example is one that I have contacts, but not confirmed…it shows as not highlighted (orange).
@K9DUD Hey Doug,
Orange = No Confirmed (meaning you have a contact with that person)
Teal = Confirmed (meaning you have a confirmed contact with that person in WRL)
If you dont have a QRZ subscription then having QRZ enabled wont do anything as they require a subscription to use their API
