Station Call sign
Good morning
I am trying to export my ADIF file to LoTW but it shows that my station call sign in WRL shows it as shidoshi1966 as opossed to my KE2FIS.
How can I correct this so that I have no errors in my logs. It did log with WRL but I need to be able to export to LoTW as well.
Any assistance will be greatly appreciated.
Thank you and 73
@KE2FIS Since you only have 1 contacts you just need to open your logbook and then click on the callsign button in the quick settings bar above the main logging fields (see screenshot). This will update your callsign for the logbook, for new qso’s going forward. Then to edit/update the existing qso you’ll just need to click the edit button on the qso record and do the same thing. (see screenshots below).
Thank you so very much, the fix worked like a charm while bringing up a few other fixes that became simple fixes on the same premise.
@KE2FIS PERFECT!! Glad you got it sorted
:+1:
Respectfully
George Marquez
Heritage Tower
82-11 37th Ave
Jackson Heights NY 11372
