Sync confirmed contacts from QRZ
So I manually added a contact on QRZ, then manually sync’d in the log into WRL, and it brought along the confirmed contact. I see on the manual sync it shows the place where it will next sync from, but it would be nice to be able to sync contact confirmations separately from importing new log entries.
Another example; I do a contact via WRL to QRZ, then the contact a few days later uploads their logs to QRZ, I’ll never see the confirm show back in WRL.
Thanks for all you are doing! :heart:
@K9DLL Hey Paul,
Yes, the latter you are referring to is due to the contact being made on WRL and then being exported to QRZ. Since the other callsign could take a day, a month, or a year to upload their contacts to QRZ there isn’t really any way for us to tell if and when the other callsign will upload their logs and hence the contact will be confirmed. I do like your idea of having a separate button to check for confirmations though, that will take a little bit of thought and research to see if there is something in the QRZ API to ONLY check for confirmations. If there is then we certainly can implement something like this.
I’ll reach out to the team and we’ll take a look and dig into seeing if this is a possibility.
