Two things draining my life force - Clear the Freq option, Green Pota highlight when park found
Don’t make me fork the WRL code base and put these in!
  1. Option to clear freq when clear button hit
  2. Light up the Park oval bright green when park is found
Let’s GOOOOOO!!! 73 Doug KC1UUH
I feel the need for speed yo!
@KC1UUH The frequency not clearing is there on purpose. It used to be like you’re suggesting but was HIGHLY requested to have it the way it was. However, with that said we are planning on a creating some logbook settings that will allow you to enable/disable this (and other settings).
We can for sure add a feature to turn the ‘Their Park’ field green, we actually have some enhancements around this already in the works. Just gotta get through this WRTC weekend.
Sounds good, thank you.
I’m patiently waiting for the enhancements as well. :slightly_smiling_face:
For the people that wanted the frequency to stay in place, did they state why they would want that? If they are sitting on a freq and calling CQ that would make sense, or if they were activating a POTA / SOTA that would also make sense, but were there other reasons I can’t think of?
I’m curious as to whether WRL has any internal analytics that would show a breakdown of how the various logs are being used from a percentage standpoint.
For example:
POTA hunting
POTA activating
Contesting
Special Event activating
etc.
I would prefer to keep the frequency in place when hunting. When you hit log contact, there is a long delay before the POTA list highlights the contact. The callsign and all other info clears. Having the frequency stay there lets me know where I was in the list. It is especially helpful when making a QSO when there are multiple operators. With all the noise lately, I can look at the frequency and find the other other ops in the POTA list by that frequency. I answered a QC the other day that had 4 ops. There was so much noise, I couldn’t make out the other call signs.
Yes, that’s understandable. And when you’re activating a park etc, you want the frequency to stay put then as well.
Adding the option to clear or not clear the frequency would be a good solution for all conditions.
Maybe the solution for me is to find another logger for hunting. I would just prefer to keep logging all in one spot.
73 Doug KC1UUH
I’m a hunter 99.995% of the time. I use the POTA page to see the Spot, I tune to the Spot, I make the contact, I log the contact by overwriting the previous frequency, and then I repeat the process. That’s why I want the frequency line to clear when the logging action is executed, but I can certainly understand why others would want the frequency to remain the same for each contact.
I am 99% sure that Brad has already stated that this option will be forthcoming so that both camps can set it up in the manner best suited for their own needs.
Can’t believe this one is taking so long! Lucky I’m not contesting right now, I’d really be complaining! hihi
@KC1UUH @W7YBY @K3ATA @K4AZE I agree or understand the desire for both clearing & not clearing the frequency slot. As for my use, when hunting I am using the WRL spotting tab and double clicking each spot as I move down the list (also using CAT control) and that auto fills everything including frequency as it changes the frequency on the radio. But I agree with @K3ATA about wanting to keep track of were you are on the spotting list which is challenging especially when it refreshes, blanks out for 2 to 15 seconds & forces the view back to the top of the list. It is an annoyance as this happens.
@K4AZE I would like to see the refresh not blank out the list (which happens in the browser & desktop app) but just instantly change with nearly no lag if possible like on the iOS app. Also I would like to see the currently selected (and tuned too) spot on the spotting list be indicated in an obvious manner to make keeping track of where you are as you move thru the list easier. Maybe highlight it or put a colored border around the active line so it is easily identifiable.
Also to clean up the spotting list I would like to see the spots from different sources combined on a single line, possibly with an additional column to indicate the source(s). This would significantly improve the visual efficiency of the spotting list.
@N2FSM we are finishing a massive overhaul on the entire spotting tab and network itself. There will be a lot of additional sources added, as well as highlights to know which spot you are currently working, have worked, etc. amongst many many other updates and enhancements. We should be releasing this in the next week or so, depending on how testing goes.
