Logic of auto fill?
I’ve noticed that when hunting POTA, if the frequency area is blank WRL will fill that in for me once I enter the activator’s call sign (usually), and the Park number will usually be filled in for me as well. Thank you for that.
Then when I actually log the contact the frequency does not clear out, so when I log my next contact I have to edit the existing frequency yet the Park number WILL automatically change to the correct park. Why one and not both fields?
Am I doing something wrong? And if not, what is the logic of keeping the frequency in place for a POTA Hunter template? I can understand that for a POTA Activator but don’t understand the reasoning for a Hunter.
Thanks
@W7YBY its that way across the board. The freq will persist due to overwhelming requests from the community.
The reason the freq and parks are getting filled in when you enter a callsign is because those callsigns are spotting in the spotting tab already.
I’m not doubting your word, but why would POTA hunters want a frequency to persist when they will be moving to a new freq as soon as they log the current contact? That doesn’t make any sense to me, especially with the new comma-separated callsign field (again, thank you) eliminating the need to go back in and reenter a frequency on a multi-operator park. Has anyone explained the logic of why they would want to have the same field persist for the next park with a different frequency?
Thanks for your time.
@W7YBY Its not hunter specific, its across the board. We will be adding logbook settings options to clear the freq field as well as other options soon.
