Using the IC-705 with ICOM remote control set for virtual port 23.
The pull down for WRL CAT does not show this port in the pull down.
It would be nice to use WRL spot screen to click a spot and the radio would change freq via a virtual port.
@K0PLT Hey Peter,
We currently don’t support virtual port software however I have been able to sort of make it work in its current configuration using VPSE.
@K4AZE Hey Brad,
Thanks, now a follow up. I got the VPSE port installed (man that’s slick) so WRL CAT now shows my virtual port COM53 as selctable . . . what radio (in the WRL CAT drop down) should be selected for use with RCForb client?
The speed of your responces are always so friging fast . . . another reason WRL is rated A+
@K0PLT honestly I’m not sure as I’ve never used (or heard of) RCForb (I’ll google it). I’ve first try with just your radio selected then maybe try the Hamlib option. Really not sure, may have to play with some different selections/options.
