I am running WSJTX 2.7.0 in Windows 10 that exposes 2237 default port of its UDP server in the localhost. I see that the UDP server is working fine as GridTracker2 is getting info and populating the map. But when I make a new contact, and accept the popup window for QSO confirmation, it does not upload the contact to the Logbook I selected when linking the WRL CAT app to WSJTX.
I am just getting started with WRL and I really like it.
Thanks and 73
@LU8BOC this is most likely just a configuration issue. If you are using the WRL cat control app, grid tracker and wsjtx or jtdx please refer to the documentation to set this up properly.
