WSJTX contact not being logged in WRL
Giving WRL another shot. Rig is flex 8600 and is connected to WRL CAT using the slice A option. WSJTX is connected to the radio and working as expected.
WRL CAT is NOT connected to the radio. Reporting is set to port 2237 in WSJTX and that is the default port in WRL Cat. Says listening for WSJTX data but nothing is being logged. I tried 4 contacts. Nothing in the CAT contact log or the main WRL Logbook.
Tnx
Greg
AB7R
BTW…running Linux Mint Cinnamon OS.
@AB7R This is just a configuration error. Are you using anything other than the UDP listener in the WRL Cat control app and WSJTX? ie GridTracker?
