I have opened a bug report for you, we will take a look at this - that’s strange. I usually use an ICOM but I do have a G90 I haven’t ever used with the CAT control, I can give it a try and see what happens.
P.S. - don’t hesitate to use the Report a Bug button in the app too, it gets to us quickly and creates a case for us.
So this is most likely just a radio config issue. While it may work with WSJTX, its just because of how WJSTX is connecting to the radio. So i’m not familiar with this radio but doing a quick google search on it and hamlib. It looks like you need to make sure you have your radio settings set to the following:
Radio Model: Select Icom IC-7100 (or obviously the G90 but users have had success with the 7100 model as the g90 is based off icom)**
Baud Rate**: Set to 19200
Flow Control: Disable CTS/RTS/DTR flow control (set to None) VOX: Ensure **VOX is OFF
Another search basically says the same thing:
G90 CAT settings
Setting
Value
Radio
Xiegu G90
CAT protocol
Icom CI-V compatible
Baud rate
19200
Data bits
8
Stop bits
1
Parity
None
Flow control
None
DTR
Off
RTS
Off
PTT
CAT
Serial device
Your G90 /dev/ttyUSBx or /dev/ttyACMx
Let me know if you are still having trouble. I suspect though its something to do with the ‘Flow Control’ as these transmit issues are almost always related to RTS/DTR settings
@GM4YMI these are all settings in your radio not in the app, although we will be adding these settings to the app before too long. Updating these settings won’t change the functionality of it working with wsjtx
@GM4YMI interesting. i’ve got Andy and James checking their radios. We’ve had a few users with g90’s run cat control without any issues so i know its possible.
@GM4YMI Here is a thread i forgot about with another user with a transmit issue like yours. he got around it by running rigctl in the terminal separately - WSL Desktop Flatpak
@KQ4SFG@AE5TX Can you guys share your settings you are running for your g90
