Hello! When exporting my log for the September VHF contest I found some issues in the Cabrillo export. When exporting contacts in the 222MHz, 900MHz, and 1296MHz bands, the correct Cabrillo format for the frequency was not followed. These contacts all rendered as the full frequency with no decimal point (i.e. 902.250 MHz rendered as “902250”). The VHF contest only accepts the following:
1.25m = 220
33cm = 902
23cm = 1.2G
Would be great if these could be added before the January contest!
Yes we will take a look. They aren’t supposed to have decimal places (MHz) everything in Cabrillo format is supposed to be formatted in Khz, however you are correct in that for certain bands they want them just listed as 144 for 2m or 420 for 70cm and in your examples 220 for 1.25m, 902 for 33cm, 1.2G for 23cm.
