LOTW - Import confirmed QSO?
Hi
I managed to connect WRL and LOTW, it’s OK.
“LOTW import completed” is noticed.
BUT confirmed QSO does not appeared in ANALYTICS.
Is it possible to see CONFIRMED QSO LOTW in WRL ?
@F5AGL I don’t think so. As far as I know, the only way to see confirmed QSOs in LOTW is on the site itself.
@F5AGL We do import confirmations on the initial import from LOTW (and QRZ - for QRZ we are finalizing some upgrades that will periodically check for new confirmations and pull those in as well). On the analytics side we do include all contacts in your account that were imported via the QRZ or LOTW import integration.
However with all that said, we dont show the analytics for contacts that were imported via an ADIF. Looking at your account it looks like you imported contacts via an ADIF and then used the LOTW import integration. This wont work, since we dont show anaylitcs for contacts imported via an ADIF.
The best thing to do (if you only have all your QSO’s in LOTW) is delete those contacts in your WRL account and use the LOTW import integration (from the integration page) to re-import those contacts. This will bring in the current confirmations and QSO’s and they will show in your analytics.
We do have a mini feature we will be adding at some point to fix this logic.
I hope this helps.
I performed the operation by re-importing the QSOs from LOTW. Now the number of “confirmed” contacts seems roughly correct (99), but on the map, very few are the correct color…
@F5AGL what do you mean by correct color?
I have 128 confirmes but only maybe 3 or 4 green color on the map.
@F5AGL Can you share a screenshot of what you’re referring to? I still don’t think i’m following.
I do not understand colors on the map…
@F5AGL There is a map key underneath the progress bar’s.
Green = Confirmed
Orange = Non Confirmed
However with that said, something doesn’t seem right as its showing 128 confirmed but there are only 3 showing green. Let me have the team look into this.
Yes, that’s what i mean… thanks !
@F5AGL This should be taken care of now. The issue was with countries coming in all upper case. we’ve fixed the logic there.
Thanks, that’s Ok now !
The bug will not come again in the future (next import) ?
@F5AGL no its been resolved
