New cat program
btw, you mention CAT functionality being disabled, the only thing I’ve ever had it display on my screen looks like an S meter, no frequency, nothing resembling CAT control.
Not having much luck with my FTDX10 and CAT control.
hey guys, I’ve been putting the integration through its paces and it’s been working pretty solid. However, today I keep getting a radio communication failed with my 7300. But on the initial needle speedometer it will show correct frequency as my radio. And i fire up WSJT after thats all opened on my screen and contacts are not transferring to the logger, forcing me to ener them manually.
I am using 7300 and NF3PJ, and the integration is working fine.
I can use the WRL logbook spotting is a little slow but it populates the radio freq very well. As far as updating log books I manually update QRZ, all the time till I see everything here is working 100% :v:, WHICH is getting Better TEAM keep up the great work
Not using cat control bu I am using the n3fjp option, I have no Profile page analytics info it says failed to load, Also Nothing is being put into the leader Board on contacts, other then day is wrong in the mornings on main log page, but correct on profile page, it works fine but the other info is important and should be easy to fix. on your end or mine let me know Rob KB6JFL.
Hello everyone! We will be hosting a call on Thursday morning regarding CAT Control BETA, and would love for each of you to join!
WRL CAT Control BETA Feedback/Planning
Thursday, February 6 · 9:00 – 10:00am
Time zone: America/Chicago
Google Meet joining info
Video call link: https://meet.google.com/caq-hwtv-nbg
If you have any trouble opening that link, let me know, and we will get it resolved.
Thank you!
Andy N0APX
WRL Product Manager
Please add your callsign below if you plan on attending!
I would like to but I have a work conference call to attend.
@KQ4SFG You can always feel free to use a tool like loom.com to share any thoughts with us!
KJ5FWC, planning on attending, subject to work requirements. Come on retirement!! :grin:
KJ5IZS PLANNING ON joining
Sorry i missed the meeting
I had no trouble downloading the software, but i am having trouble with getting it working. In the way of sending my logged contacts, mainly wsjt-x. I’ve tried every logging software for PC know to mankind. Whereas I am very much looking forward to what you guys have in store in the future, I have for now settled with log4om. An integration with them at some point would be epic.
I have been able to use the WSJT-X integration, but only if I do not have GridTracker2 open. My GridTracker2 updates QRZ and LOTW, so there may be some interference with the WRL update. Any suggestions or workarounds, so I can use both?
@KD3B I’ll check with the developer to see if there are any issues with two softwares listening to the WSJT-X UDP port at the same time.
Windows 11 Cat Control Beta 1.0.2 does not enumerate virtual coom ports only physical ports. I cannot use physical ports because they are being share by other apps, Using VSPE for configuring virtual com ports. This is a very common setup for hams, using virial ports to share and integrate multiple apps to the same radio.
73 de ws1m
bammi
I tried out the new CAT software today, and encountered a few problems. The application wouldn’t stay connected to my Yaesu FT-710, even though the port and baud rate was correct. It did work for less than a minute, but then disconnected. Multiple errors appeared, and blocked the “Settings” button, so I had to shut down and reboot the app. Hopefully these issues will be resolved by an update.
@N5WIN yes there are several known issues with the 710, dx10 & 101mp that we are working on.
Generally WRLCat control is reasonably stable but it will drop 4 or 5 times over a 30 minute period. This is on a FTDX10.
I haven’t been able to pin it down or been able to recreate the problem - it’s just random.
You mention that there are known problems with FTDX10 … Are these documented so we can review what those known problems are?
@KO6JGA not currently. Hamlib didn’t add support for certain yaesu models until recently, we are adding them in now.
