Qrz import
When you import from qrz, does it bring unconfirmed also?
would like to see if non confirmed can get confirmed here!
73s ve3md
@VE3MD Good morning,
If you use the QRZ integration and import your QSO’s from QRZ to your WRL account that way then yes it will pull in all QSO’s (both confirmed and unconfirmed) we are close to pushing an update that will randomly check for new confirmations and pull in just the confirmation for the QSO(s).
Also is there a way to automatically import contacts from qrz ? This way you wouldn’t have to do 2 logs! I am talking on a daily basis.
73s ve3md
@VE3MD Good Morning,
Yes you’ll need to go World Radio League and in the ‘Import QSOs from QRZ.COM’ section add your QRZ API key from your QRZ logbook settings. Then select the WRL Logbook you want to import your QSO’s into.
