Several instances of the call signs not clearing from the screen after the contact has been logged happened over the past two days. But very sporadic and not consistent at all.
When KC0MPG was logged and then I went to log W5WPS, KC0MPG was still on the form AND the note that I had entered for him was still in there too so I had to clear out both.
W5WPS was logged at the end of the day (5/3) and as I entered him again in the new day (5/4) his call was still in there BUT it was showing as a dupe even though it was a new day. I did a Shift+Refresh and the Dupes remained.
They were POTA contacts. I have had numerous POTA contacts at the same park just before and just after a new UTC day and they have not flagged as Dupes in the past which is why I called this out.
The second part of the report was regarding the contact prior to the Dupe in which the call sign and the comments in the Notes section remained after logging and I had to manually clear them out.
I also had sporadic cases of the call sign not clearing out after being logged this past weekend but I did not make a note of them.
@W7YBY I would try doing a hard refresh to clear you cache because these things have been fixed either in the past couple of weeks or recently and it sounds like somehow you are pulling a cached version. Try holding shift while clicking the refresh button in your browser. I’ll take a look at your data though.
